# Linphoneシェルコマンド
**URL:** https://forum.ficusonline.com/t/linphone/41
**Category:** Orange Pi
**Created:** [2016 年 11 月 2 日午前 11:05 UTC](https://forum.ficusonline.com/t/linphone/41 "2016-11-02T11:05:20Z")
**Posts on this page:** 2
**Page:** 1
<div class="post-metadata">
### Author: ![tk-fuse](https://forum.ficusonline.com/user_avatar/forum.ficusonline.com/tk-fuse/32/255_2.png) [@tk-fuse](https://forum.ficusonline.com/u/tk-fuse)
#### Post date: [2016 年 11 月 2 日午前 11:05 UTC](https://forum.ficusonline.com/t/linphone/41/1 "2016-11-02T11:05:21Z")
NAME
       linphonecsh - Sends a command to a linphonec running in daemon mode, and exits.
SYNTAX
       linphonecsh init <optional linphonec args>
       linphonecsh exit
       linphonecsh generic <linphonec command line surrounded by quotes>
       linphonecsh register --username <username> --host <proxy> --password <password>
       linphonecsh unregister
       linphonecsh dial <sip address or number>
       linphonecsh status <domain = one of 'register', 'hook', 'autoanswer'>
       linphonecsh --help
DESCRIPTION
       Linphonecsh is a small utility to send basic commands to a linphonec (console
       mode linphone) process. Unlike linphonec, linphonecsh does not wait commands
       from standard input: it takes the command from its arguments and sends it using
       unix pipe to a linphonec process started in daemon mode. The motivation for
       this tool is for example to simply execute voip calls from scripts, web-servers,
       or javascript web pages.
       The very first thing to do before doing actions is to ask linphonecsh to spawn a
       linphonec daemon using
       linphonecsh init
              The resulting linphonec daemon does not read or write any configuration
              file.
              When the linphonec daemon is no more needed, the following commands makes
              it exit properly:
       linphonecsh exit
FILES
       By default a linphonec started as a daemon by 'linphonecsh init' does not use a
       config file.
ENVIRONMENT VARIABLES
EXAMPLES
AUTHORS
       Simon Morlat <simon.morlat at linphone.org>
SEE ALSO
       linphonec(1) sipomatic(1) linphone(1)
#### Post date: [2016 年 11 月 2 日午前 11:13 UTC](https://forum.ficusonline.com/t/linphone/41/2 "2016-11-02T11:13:39Z")
linphonecsh <action> [arguments]
  where action is one of
    	init : spawn a linphonec daemon (first step to make other actions)
    			followed by the arguments sent to linphonec
    	generic : sends a generic command to the running linphonec daemon
    			followed by the generic command surrounded by quotes,
    			 for example "call sip:joe@example.net"
    	register	: register; arguments are
    			--host <host>
    	unregister	: unregister
    	dial : dial <sip uri or number>
    	status : can be 'status register', 'status autoanswer' or 'status hook'
    	soundcard	: can be 'soundcard capture', 'soundcard playback', 'soundcard ring',
    			 followed by an optional number representing the index of the soundcard,
    			 in which case the soundcard is set instead of just read.
    	exit : make the linphonec daemon to exit.
