Orange Pi Lite LIRC設定
<環境>
Linux orangepilite 3.4.113-sun8i #10 SMP PREEMPT Thu Feb 23 19:55:00 CET 2017 armv7l armv7l armv7l GNU/Linux
LIRCは標準でインストールされています。Orange Pi PCの場合と設定はほぼ同じですが、 /etc/lirc/hardware.conf の設定が少し異なります。以下の指定箇所を確認・変更します。
$ sudo pico /etc/lirc/hardware.conf
# /etc/lirc/hardware.conf
#Chosen Remote Control
REMOTE="car_remote"
REMOTE_MODULES="sunxi_cir"       ここを指定
REMOTE_DRIVER="default"        ここを指定
REMOTE_DEVICE="/dev/lirc0"       ここを指定
REMOTE_SOCKET=""
REMOTE_LIRCD_CONF="/etc/lirc/lircd.conf" ここを指定
REMOTE_LIRCD_ARGS="--uinput"     ここを指定
#Chosen IR Transmitter
TRANSMITTER="None"
TRANSMITTER_MODULES=""
TRANSMITTER_DRIVER=""
TRANSMITTER_DEVICE=""
TRANSMITTER_SOCKET=""
TRANSMITTER_LIRCD_CONF=""
TRANSMITTER_LIRCD_ARGS=""
#Disable kernel support.
#Typically, lirc will disable in-kernel support for ir devices in order to
#handle them internally.  Set to false to prevent lirc from disabling this
#in-kernel support.
#DISABLE_KERNEL_SUPPORT="true"
#Enable lircd
START_LIRCD="true"      ここを指定
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD="false"
#Try to load appropriate kernel modules
LOAD_MODULES="true"
# Default configuration files for your hardware if any
LIRCMD_CONF=""
#Forcing noninteractive reconfiguration
#If lirc is to be reconfigured by an external application
#that doesn't have a debconf frontend available, the noninteractive
#frontend can be invoked and set to parse REMOTE and TRANSMITTER
#It will then populate all other variables without any user input
#If you would like to configure lirc via standard methods, be sure
#to leave this set to "false"
FORCE_NONINTERACTIVE_RECONFIGURATION="false"
START_LIRCMD=""
