Dockerコマンド、Dockerfile・Compose file リファレンス
Runtime privilege and Linux capabilities
Option Description
–cap-add Add Linux capabilities
–cap-drop Drop Linux capabilities
–privileged Give extended privileges to this container
–device= Allows you to run devices inside the container without the --privileged flag.
Capability Key Capability Description
AUDIT_CONTROL Enable and disable kernel auditing; change auditing filter rules; retrieve auditing status and filtering rules.
AUDIT_READ Allow reading the audit log via multicast netlink socket.
BLOCK_SUSPEND Allow preventing system suspends.
BPF Allow creating BPF maps, loading BPF Type Format (BTF) data, retrieve JITed code of BPF programs, and more.
CHECKPOINT_RESTORE Allow checkpoint/restore related operations. Introduced in kernel 5.9.
DAC_READ_SEARCH Bypass file read permission checks and directory read and execute permission checks.
IPC_LOCK Lock memory (mlock(2), mlockall(2), mmap(2), shmctl(2)).
IPC_OWNER Bypass permission checks for operations on System V IPC objects.
LEASE Establish leases on arbitrary files (see fcntl(2)).
LINUX_IMMUTABLE Set the FS_APPEND_FL and FS_IMMUTABLE_FL i-node flags.
MAC_ADMIN Allow MAC configuration or state changes. Implemented for the Smack LSM.
MAC_OVERRIDE Override Mandatory Access Control (MAC). Implemented for the Smack Linux Security Module (LSM).
NET_ADMIN Perform various network-related operations.
NET_BROADCAST Make socket broadcasts, and listen to multicasts.
PERFMON Allow system performance and observability privileged operations using perf_events, i915_perf and other kernel subsystems
SYS_ADMIN Perform a range of system administration operations.
SYS_BOOT Use reboot(2) and kexec_load(2), reboot and load a new kernel for later execution.
SYS_MODULE Load and unload kernel modules.
SYS_NICE Raise process nice value (nice(2), setpriority(2)) and change the nice value for arbitrary processes.
SYS_PACCT Use acct(2), switch process accounting on or off.
SYS_PTRACE Trace arbitrary processes using ptrace(2).
SYS_RAWIO Perform I/O port operations (iopl(2) and ioperm(2)).
SYS_RESOURCE Override resource Limits.
SYS_TIME Set system clock (settimeofday(2), stime(2), adjtimex(2)); set real-time (hardware) clock.
SYS_TTY_CONFIG Use vhangup(2); employ various privileged ioctl(2) operations on virtual terminals.
SYSLOG Perform privileged syslog(2) operations.
WAKE_ALARM Trigger something that will wake up the system.
