sh, bash: シェルコマンド・スクリプト リファレンス
Bashリファレンス
set
$ set --help (or $ help set)
set: set [-abefhkmnptuvxBCHP] [-o option-name] [--] [arg ...]
    Set or unset values of shell options and positional parameters.
    Change the value of shell attributes and positional parameters, or
    display the names and values of shell variables.
    Options:
      -a  Mark variables which are modified or created for export.
      -b  Notify of job termination immediately.
      -e  Exit immediately if a command exits with a non-zero status.
      -f  Disable file name generation (globbing).
      -h  Remember the location of commands as they are looked up.
      -k  All assignment arguments are placed in the environment for a
          command, not just those that precede the command name.
      -m  Job control is enabled.
      -n  Read commands but do not execute them.
      -o option-name
ulimit
$ ulimit --help (or $ help ulimit)
ulimit: ulimit [-SHabcdefiklmnpqrstuvxPT] [limit]
    Modify shell resource limits.
    Provides control over the resources available to the shell and processes
    it creates, on systems that allow such control.
    Options:
      -S	use the `soft' resource limit
      -H	use the `hard' resource limit
      -a	all current limits are reported
      -b	the socket buffer size
      -c	the maximum size of core files created
      -d	the maximum size of a process's data segment
      -e	the maximum scheduling priority (`nice')
      -f	the maximum size of files written by the shell and its children
      -i	the maximum number of pending signals
      -k	the maximum number of kqueues allocated for this process
      -l	the maximum size a process may lock into memory
      -m	the maximum resident set size
      -n	the maximum number of open file descriptors
      -p	the pipe buffer size
      -q	the maximum number of bytes in POSIX message queues
      -r	the maximum real-time scheduling priority
      -s	the maximum stack size
      -t	the maximum amount of cpu time in seconds
      -u	the maximum number of user processes
      -v	the size of virtual memory
      -x	the maximum number of file locks
      -P	the maximum number of pseudoterminals
      -T	the maximum number of threads
exec
$ exec --help (or $ help exec)
exec: exec [-cl] [-a name] [command [arguments ...]] [redirection ...]
    Replace the shell with the given command.
    Execute COMMAND, replacing this shell with the specified program.
    ARGUMENTS become the arguments to COMMAND.  If COMMAND is not specified,
    any redirections take effect in the current shell.
    Options:
      -a name	pass NAME as the zeroth argument to COMMAND
      -c	execute COMMAND with an empty environment
      -l	place a dash in the zeroth argument to COMMAND
