PrestaShop + Nginx
PrestaShop Nginx Congiguration
Adminディレクトリ(sub directory:store) はフォルダ名を変更して、Nginxの設定にも反映させること。
# [REQUIRED EDIT] Change this block to your admin folder
    location /store/your-admin/ {
        if (!-e $request_filename) {
            rewrite ^/store/.*$ /store/your-admin/index.php last;
php-fpmセクション(sub directory:store) は以下の様に変更(Dockerコンテナphp-fpm指定)。
location ~ \.php$ {
		# Verify that the file exists, redirect to index if not
		#try_files $fastcgi_script_name /index.php$uri&$args =404;
		alias /$1;
		include fastcgi_params;
		fastcgi_index index.php;
		fastcgi_split_path_info ^\/store\/(.+\.php)(.*)$;
		# fastcgi_param  HTTPS 'on';
		fastcgi_param PATH_INFO       $fastcgi_path_info;
		fastcgi_param PATH_TRANSLATED $fastcgi_path_info;
		fastcgi_param SCRIPT_FILENAME $fastcgi_script_name;
		fastcgi_pass prestashop-fpm:9000;
		fastcgi_keep_conn on;
		fastcgi_connect_timeout 10s;
		fastcgi_read_timeout 30s;
		fastcgi_send_timeout 30s;
		# In case of long loading or 502 / 504 errors
		fastcgi_buffer_size 256k;
		fastcgi_buffers 256 16k;
		fastcgi_busy_buffers_size 256k;
		client_max_body_size 10m;
PrestaShop(1.7.6.5)をNginxのSSL対応後にインストールしたため、以下リダイレクトエラー発生
err_too_many_redirects
Prestashopデータベースに直接アクセスし、configrationテーブルのPS_SSL_ENABLEDとPS_SSL_ENABLED_EVERYWHEREの値を “1” に書換えます。
504 gateway time-out
デザイン —> Email Theme —> Generate emails
メールのテンプレート変換に時間を要するため発生。
以下設定時間を見直し。30s ---> 60s
fastcgi_read_timeout 60s;
fastcgi_send_timeout 60s;
Nginx設定アップデート
PrestasShopロケーションのセクション更新
/etc/nginx/conf.d/default.conf
location ~ [^/store/]\.php(/|$) {
		# Split $uri to $fastcgi_script_name and $fastcgi_path_info.
		fastcgi_split_path_info ^\/store\/(.+?\.php)(.*)$;
		# Ensure that the requested PHP script exists before passing it
		# to the PHP-FPM.
		try_files $fastcgi_script_name =404;
		# Environment variables for PHP.
		# Uncomment these in case of long loading or 502/504 errors.
		# [EDIT] Connection to PHP-FPM unix domain socket.
