Scala導入ティップス
ABSTRACT CLASSES
Traitではパラメータを定義できないため、パラメータを定義できるTraitとして利用。
Javaコードから呼び出す際にも使用。
拡張クラスは、abstract classを一つだけしか利用できない。
以下Traitでは変数を定義できない。
trait Animal(name: String) --->コンパイルエラー
abstract class により変数を定義。
abstract class Animal(name: String)
Ex) Pet(name) が abstract class であることを示す。
abstract class Pet (name: String) {
    def speak: Unit = println(s"My name is $name")
class Dog(name: String) extends Pet(name)
val d = new Dog("Fido")
d.speak
クラスメンバーにabstract typeを含む場合(具体的な値やメソッドが定義されていない)にもabstract classを使用。
// Scala program to illustrate how to
// create an abstract class
// Abstract class
abstract class myauthor
	// abstract method
	def details()
// GFG class extends abstract class
class GFG extends myauthor
	def details()
		println("Author name: Ankita Saini")
		println("Topic name: Abstract class in Scala")
object Main
	// Main method
	def main(args: Array[String])
		// objects of GFG class
		var obj = new GFG()
		obj.details()
ABSTRACT TYPE MEMBERS
具体的な型のタイプ、値、メソッドなどを定義していないクラスメンバー
// Scala program of abstract type member
// Declaring an abstract class
abstract class vehicle (name:String)
	// This is an abstract member
	// with undefined implementation
	val category: String
	// A function that is used to print
	// the value of the abstract member
	def car_type{ println(category) }
	override def toString = s" The vehicle type is $category"
// Now extend the classes bike, car,
// truck and bus and provide values
// for the variable type
class car (name:String) extends vehicle (name)
	// assigning the value of
	// the abstract member as car
	val category = "car"
class bike (name:String) extends vehicle (name)
	// the abstract member as bike
	val category = "bike"
class bus (name:String) extends vehicle (name)
	// the abstract member as bus
	val category = "bus"
class truck (name:String) extends vehicle (name)
	// the abstract member as truck
	val category = "truck"
object AbstractFieldsDemo extends App
	// assigning the name as Honda in the abstract
	// class where the category value is car
	val car = new car("Honda")
	// assigning the name as Yamaha in the abstract
	// class where the category value is bike
	val bike = new bike("Yamaha")
	// assigning the name as Tata in the abstract
	// class where the category value is bus
	val bus = new bus("Tata")
	// assigning the name as Ashok_Leyland in the
	// abstract class where the category value is truck
	val truck = new truck("Ashok_Leyland")
	// implementing the function
	// car_type for the object car
	car.car_type
	// car_type for the object bus
	bus.car_type
	// car_type for the object truck
	truck.car_type
	bike.car_type
	println(car)
	println(bus)
	println(truck)
	println(bike)
Keywords/reserved symbols
// Keywords
<-  // Used on for-comprehensions, to separate pattern from generator
=>  // Used for function types, function literals and import renaming
// Reserved
( )        // Delimit expressions and parameters
[ ]        // Delimit type parameters
{ }        // Delimit blocks
.          // Method call and path separator
// /* */   // Comments
#          // Used in type notations
:          // Type ascription or context bounds
<: >:      // Upper and lower bounds
<%         // View bounds (deprecated)
" """      // Strings
'          // Indicate symbols and characters
@          // Annotations and variable binding on pattern matching
`          // Denote constant or enable arbitrary identifiers
,          // Parameter separator
;          // Statement separator
_*         // vararg expansion
_          // Many different meanings
MODIFIERS
Method modifiers should be given in the following order (when each is applicable):
Annotations, each on their own line
Override modifier (override)
Access modifier (protected, private)
Implicit modifier (implicit)
Final modifier (final)
def
@Transaction
@throws(classOf[IOException])
override protected final def foo(): Unit = {
Override
サブクラスによる元クラスの内容(メソッド)を上書き(変数の定義は不変)
Self Reference(this)
On the inside of a class, the name this represents the object on which the current method is executed.
Add the functions less and max to the class Rational.
  class Rational(x: Int, y: Int) {
    def less(that: Rational) =
    numer * that.denom < that.numer * denom
    def max(that: Rational) =
      if (this.less(that)) that else this
Note that a simple name x, which refers to another member of the class, is an abbreviation of this.x. Thus, an equivalent way to formulate less is as follows.
    this.numer * that.denom < that.numer * this.denom
Predef
Assertions
These methods support program verification and runtime correctness.
final def assert(assertion: Boolean, message: => Any): Unit
Tests an expression, throwing an AssertionError if false.
def assert(assertion: Boolean): Unit
final def assume(assumption: Boolean, message: => Any): Unit
def assume(assumption: Boolean): Unit
final def require(requirement: Boolean, message: => Any): Unit
Tests an expression, throwing an IllegalArgumentException if false.
def require(requirement: Boolean): Unit
def, val, var
def - defines an immutable label for the right side content which is lazily evaluated - evaluate by name.
val - defines an immutable label for the right side content which is eagerly/immediately evaluated - evaluated by value.
var - defines a mutable variable, initially set to the evaluated right side content.
LazyLists " #:: "
以下のようなフィボナッチ数列の演算で、#:: とすることで結果を呼び出さない限り演算しないようにする。
scala> def fibFrom(a: Int, b: Int): LazyList[Int] = a #:: fibFrom(b, a + b)
パラメータ入力しても演算結果を返さない。
scala> val fibs = fibFrom(1, 1).take(7)
val fibs: scala.collection.immutable.LazyList[Int] = LazyList(<not computed>)
toListメソッドによる呼び出し
scala> fibs.toList
val res0: List[Int] = List(1, 1, 2, 3, 5, 8, 13)
POLYMORPHIC METHODS
型をパラメータとする場合 [ ] 、変数は ( ) を用います。型をパラメータと定義することでメソッドの自由度が大幅に増加します。 println 等による具体的な値を入力して呼び出しする際には [ ] は省略できます(Scalaコンパイラーによる自動認識)。
def listOfDuplicates[A](x: A, length: Int): List[A] = {
  if (length < 1)
    Nil
  else
    x :: listOfDuplicates(x, length - 1)
println(listOfDuplicates[Int](3, 4))  // List(3, 3, 3, 3)
println(listOfDuplicates("La", 8))  // List(La, La, La, La, La, La, La, La)
コンパイラオプション
scala.sbt
scalaVersion := "2.13.3"
scalacOptions ++= Seq(
  "-encoding", "utf8", // Option and arguments on same line
  "-Xfatal-warnings",  // New lines for each options
  "-deprecation",
  "-unchecked",
  "-language:implicitConversions",
  "-language:higherKinds",
  "-language:existentials",
  "-language:postfixOps"
ScalaTest
ScalaTestホーム
バージョン別ドキュメント
