Bootstrap 4 Icons
W3Schools offers free online tutorials, references and exercises in all the major languages of the web. Covering popular subjects like HTML, CSS, JavaScript, Python, SQL, Java, and many, many more.
<link rel="stylesheet" href="https://use.fontawesome.com/releases/v5.7.0/css/all.css" integrity="sha384-lZN37f5QGtY3VHgisS14W3ExzMWZxybE1SJSEsQp9S+oqd12jhcu+A56Ebc1zFSJ" crossorigin="anonymous">
Then, add the name of the icon class to any inline HTML element (like <i> or <span>):
Example
<i class="fas fa-cloud"></i>
<i class="fas fa-coffee"></i>
<i class="fas fa-car"></i>
<i class="fas fa-file"></i>
<i class="fas fa-bars"></i>
Text
Documentation and examples for common text utilities to control alignment, wrapping, weight, and more.
<p class="font-weight-bold">Bold text.</p>
<p class="font-weight-bolder">Bolder weight text (relative to the parent element).</p>
<p class="font-weight-normal">Normal weight text.</p>
<p class="font-weight-light">Light weight text.</p>
<p class="font-weight-lighter">Lighter weight text (relative to the parent element).</p>
<p class="font-italic">Italic text.</p>
Colors
Flex
Quickly manage the layout, alignment, and sizing of grid columns, navigation, components, and more with a full suite of responsive flexbox utilities. For more complex implementations, custom CSS may be necessary.
Containers
Grid System
Bootstrap’s grid system uses a series of containers, rows, and columns to layout and align content. It’s built with flexbox and is fully responsive. Below is an example and an in-depth explanation for how the grid system comes together. | Use our...
Spacing
Where property is one of:
m - for classes that set margin
p - for classes that set padding
Where sides is one of:
t - for classes that set margin-top or padding-top
b - for classes that set margin-bottom or padding-bottom
s - (start) for classes that set margin-left or padding-left in LTR, margin-right or padding-right in RTL
e - (end) for classes that set margin-right or padding-right in LTR, margin-left or padding-left in RTL
x - for classes that set both *-left and *-right
y - for classes that set both *-top and *-bottom
blank - for classes that set a margin or padding on all 4 sides of the element
Where size is one of:
0 - for classes that eliminate the margin or padding by setting it to 0
1 - (by default) for classes that set the margin or padding to $spacer * .25
2 - (by default) for classes that set the margin or padding to $spacer * .5
3 - (by default) for classes that set the margin or padding to $spacer
4 - (by default) for classes that set the margin or padding to $spacer * 1.5
5 - (by default) for classes that set the margin or padding to $spacer * 3
auto - for classes that set the margin to auto
List Group
<div class="list-group">
<a href="#" class="list-group-item list-group-item-action active" aria-current="true">
The current link item
</a>
<a href="#" class="list-group-item list-group-item-action">A second link item</a>
<a href="#" class="list-group-item list-group-item-action">A third link item</a>
<a href="#" class="list-group-item list-group-item-action">A fourth link item</a>
<a href="#" class="list-group-item list-group-item-action disabled" tabindex="-1" aria-disabled="true">A disabled link item</a>
Images
img-fluid による幅100%自動イメージサイズ
所属エレメントの可変幅に応じてイメージ幅サイズも可変(表示領域幅100%、高さ自動)
mx-auto d-block でセンター配置
<img src="..." class="img-fluid mx-auto d-block" alt="...">
Display Property
各要素間の表示配列指定
hover, focus, active
:hover による要素内カーソル移動時の背景色設定
hover : マウス移動時に背景色変化
focus : マウス押下時に背景色変化(マウスをリリースしてもその背景色を維持)
active : マウス押下時にのみ背景色変化(マウスリリースすると元の背景色へ戻る)
リストグループ要素
footer .footer-top .list-group-item {
background-color: #184f8a;
border-color: var(--gray);
color: white;
footer .footer-top .list-group-item:hover {
background-color: #0a2644;
color: white;
ボタン
.btn-primary {
color: #FFFFFF;
/*font-size: 18px;*/
text-align: center;
border-radius: 6px;
background: var(--blue);
border-color: var(--blue);
.btn-outline-primary {
color: var(--blue);
.btn-outline-primary:hover {
background-color: var(--purple);
border-color: var(--purple);
.btn-secondary {
color: var(--blue);
text-align: center;
border-radius: 6px;
background-color: #FFFFFF;
.btn-secondary:hover {
background-color: var(--dark-purple);
.btn-primary:hover {
background: var(--light-purple);
border-color: var(--light-purple);
