UbuntuによるサーバシステムのボリュームをLVMにより管理。
LVM : ArchWiki
https://wiki.archlinux.org/title/LVM
Physical volume (PV)
Unix block device node, usable for storage by LVM. Examples: a hard disk, an MBR or GPT partition, a loopback file, a device mapper device (e.g. dm-crypt). It hosts an LVM header.Volume group (VG)
Group of PVs that serves as a container for LVs. PEs are allocated from a VG for a LV.Logical volume (LV)
“Virtual/logical partition” that resides in a VG and is composed of PEs. LVs are Unix block devices analogous to physical partitions, e.g. they can be directly formatted with a file system.Physical extent (PE)
The smallest contiguous extent (default 4 MiB) in the PV that can be assigned to a LV. Think of PEs as parts of PVs that can be allocated to any LV.
LVMによる論理ボリュームの変更(拡張)
Note: lvresize(8) provides more or less the same options as the specialized lvextend(8) and lvreduce(8) commands, while allowing to do both types of operation. Notwithstanding this, all those utilities offer a
-r
/--resizefs
option which allows to resize the file system together with the LV using fsadm(8) (ext2 , ext3, ext4, ReiserFS and XFS supported). Therefore it may be easier to simply uselvresize
for both operations and use--resizefs
to simplify things a bit, except if you have specific needs or want full control over the process.lvresizeはlvextendとlvreduceの機能を含んでいるため、特に理由がなければlvresizeを使用。
Resizing the logical volume and file system in one go
Note: Only ext2 , ext3, ext4, ReiserFS and XFS file systems are supported. For a different type of file system see #Resizing the logical volume and file system separately.
ext2 , ext3, ext4, ReiserFS , XFS ファイルシステムの場合のみ
--resizefs
オプションを付与してファイルシステムのリサイズも可能。
ボリュームグループ/論理ボリュームを指定して lvresize
コマンドを実行
Extend the logical volume mediavol
in MyVolGroup
by 10 GiB and resize its file system all at once:
# lvresize -L +10G --resizefs MyVolGroup/mediavol
Set the size of logical volume mediavol
in MyVolGroup
to 15 GiB and resize its file system all at once:
# lvresize -L 15G --resizefs MyVolGroup/mediavol
If you want to fill all the free space on a volume group, use the following command:
# lvresize -l +100%FREE --resizefs MyVolGroup/mediavol
For file systems not supported by fsadm(8) will need to use the appropriate utility to resize the file system before shrinking the logical volume or after expanding it.
To extend logical volume mediavol
within volume group MyVolGroup
by 2 GiB without touching its file system:
$ sudo lvresize -L +2G MyVolGroup/mediavol
Now expand the file system (ext4 in this example) to the maximum size of the underlying logical volume:
$ sudo resize2fs /dev/MyVolGroup/mediavol
To reduce the size of logical volume mediavol
in MyVolGroup
by 500 MiB, first calculate the resulting file system size and shrink the file system (ext4 in this example) to the new size:
$ sudo resize2fs /dev/MyVolGroup/mediavol *NewSize*
When the file system is shrunk, reduce the size of logical volume:
$ sudo lvresize -L -500M MyVolGroup/mediavol
ボリュームグループの確認(PE : Physical Extendsフリー容量の確認)
$ sudo vgdisplay
--- Volume group ---
VG Name ubuntu-vg
System ID
Format lvm2
Metadata Areas 1
Metadata Sequence No 2
VG Access read/write
VG Status resizable
MAX LV 0
Cur LV 1
Open LV 1
Max PV 0
Cur PV 1
Act PV 1
VG Size <928.46 GiB
PE Size 4.00 MiB
Total PE 237685
Alloc PE / Size 25600 / 100.00 GiB
Free PE / Size 212085 / <828.46 GiB
VG UUID xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
論理ボリュームの確認
$ sudo lvdisplay
--- Logical volume ---
LV Path /dev/ubuntu-vg/ubuntu-lv
LV Name ubuntu-lv
VG Name ubuntu-vg
LV UUID xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
LV Write Access read/write
LV Creation host, time ubuntu-server, 2022-07-18 02:29:35 +0000
LV Status available
# open 1
LV Size 100.00 GiB
Current LE 25600
Segments 1
Allocation inherit
Read ahead sectors auto
- currently set to 256
Block device 253:0
論理ボリュームのマウントポイントの確認
$ sudo lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 79.9M 1 loop /snap/lxd/22923
loop1 7:1 0 44.7M 1 loop /snap/snapd/15534
loop2 7:2 0 61.9M 1 loop /snap/core20/1405
loop3 7:3 0 61.9M 1 loop /snap/core20/1518
loop4 7:4 0 47M 1 loop /snap/snapd/16292
sda 8:0 0 931.5G 0 disk
├─sda1 8:1 0 1G 0 part /boot/efi
├─sda2 8:2 0 2G 0 part /boot
└─sda3 8:3 0 928.5G 0 part
└─ubuntu--vg-ubuntu--lv 253:0 0 100G 0 lvm /
sr0 11:0 1 1024M 0 rom
ファイルシステムの確認
$ df -Th
Filesystem Type Size Used Avail Use% Mounted on
tmpfs tmpfs 783M 1.8M 781M 1% /run
/dev/mapper/ubuntu--vg-ubuntu--lv ext4 98G 33G 61G 35% /
tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm
tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock
/dev/sda2 ext4 2.0G 127M 1.7G 7% /boot
/dev/sda1 vfat 1.1G 5.3M 1.1G 1% /boot/efi
tmpfs tmpfs 783M 4.0K 783M 1% /run/user/1000
フリースペースを100%使用する場合
$ sudo lvresize -l +100%FREE /dev/mapper/ubuntu--vg-ubuntu--lv
$ sudo resize2fs /dev/mapper/ubuntu--vg-ubuntu--lv
ファイルシステムが ext4
である場合は、ボリュームグループ内の論理ボリュームを指定して
$ sudo lvresize -l +100%FREE --resizefs ubuntu-vg/ubuntu-lv
