プログラミング言語 Rust メモ
プログラミング言語 Rust
https://github.com/rust-lang/book
The Rust Programming Language - The Rust Programming Language
ユーザ環境にインストール (Ubuntu 22.04)
$ curl --proto '=https' --tlsv1.2 https:/sh.rustup.rs -sSf | sh
アップデート
$ rustup update
アンインストール
$ rustup self uninstall
cargo: プロジェクト作成からビルド、起動まで
  • create a project using cargo new.
  • build a project using cargo build.
  • build and run a project in one step using cargo run.
  • build a project without producing a binary to check for errors using cargo check.
  • Instead of saving the result of the build in the same directory as our code, Cargo stores it in the target/debug directory.
$ cargo -h
Rust's package manager
Usage: cargo [+toolchain] [OPTIONS] [COMMAND]
       cargo [+toolchain] [OPTIONS] -Zscript <MANIFEST_RS> [ARGS]...
Options:
  -V, --version             Print version info and exit
      --list                List installed commands
      --explain <CODE>      Run `rustc --explain CODE`
  -v, --verbose...          Use verbose output (-vv very verbose/build.rs output)
  -q, --quiet               Do not print cargo log messages
      --color <WHEN>        Coloring: auto, always, never
  -C <DIRECTORY>            Change to DIRECTORY before doing anything (nightly-only)
      --frozen              Require Cargo.lock and cache are up to date
      --locked              Require Cargo.lock is up to date
      --offline             Run without accessing the network
      --config <KEY=VALUE>  Override a configuration value
  -Z <FLAG>                 Unstable (nightly-only) flags to Cargo, see 'cargo -Z help' for details
  -h, --help                Print help
Some common cargo commands are (see all commands with --list):
    build, b    Compile the current package
    check, c    Analyze the current package and report errors, but don't build object files
    clean       Remove the target directory
    doc, d      Build this package's and its dependencies' documentation
    new         Create a new cargo package
    init        Create a new cargo package in an existing directory
    add         Add dependencies to a manifest file
    remove      Remove dependencies from a manifest file
    run, r      Run a binary or example of the local package
    test, t     Run the tests
    bench       Run the benchmarks
    update      Update dependencies listed in Cargo.lock
    search      Search registry for crates
    publish     Package and upload this package to the registry
    install     Install a Rust binary. Default location is $HOME/.cargo/bin
    uninstall   Uninstall a Rust binary
作成したプロジェクトフォルダ内で $ cargo -doc --open コマンドを実行すると、依存関係のドキュメントがブラウザに表示されます。
The Rust community’s crate registry
https://crates.io/
