Flexisip : SIPネットワークと電話網との相互接続について
https://linphone.org/news/flexisip-allows-interconnection-pstn-networks
ubuntu-flexisipコンテナ内でデバックモードで起動
$ docker compose -p project exec ubuntu-flexisip bash
# bin/flexisip --server b2bua --debug
[b2bua-server]のapplicationでsip-bridgeを指定(デフォルトはtrenscrypter)し、関連セクションを設定。[b2bua-server::sip-bridge], [module::B2bua]
flexisip.conf
## Flexisip back-to-back user agent server parameters.
[b2bua-server]
# The type of application that will handle calls bridged through
# the B2BUA. Possible values:
# - `trenscrypter` Bridge different encryption types on both ends
# transparently.
# - `sip-bridge` Bridge calls through an external SIP provider.
# (e.g. for PSTN gateways)
# Default: trenscrypter
application=sip-bridge
# SIP uri on which the back-to-back user agent server is listening
# on.
# Default: sip:127.0.0.1:6067;transport=tcp
#transport=sip:127.0.0.1:6067;transport=tcp
# Directory where to store b2bua core local files
# Default
# Default: /var/opt/belledonne-communications/flexisip/b2b
#data-directory=/var/opt/belledonne-communications/flexisip/b2b
# The Flexisip proxy URI to which the B2bua server should send all
# its outgoing SIP requests.
# Default: sip:127.0.0.1:5060;transport=tcp
#outbound-proxy=sip:127.0.0.1:5060;transport=tcp
## External SIP Provider Bridge parameters.
# Path to a file containing the accounts to use for external SIP
# bridging, organised by provider, in JSON format.
# Here is a template of what should be in this file:
# [{"name": "<user-friendly provider name for CLI output>",
# "pattern": "<regexp to match callee address>",
# "outboundProxy": "<sip:some.provider.example.com;transport=tls>",
# "registrationRequired": true,
# "maxCallsPerLine": 42,
# "accounts": [{
# "uri": "sip:[email protected]",
# "userid": "<optional (e.g. an API key)>",
# "password": "<password or API token>"
# Default: example-path.json
providers=providers=/path/to/your/providers-file.json
## This module is in charge of intercepting calls and route them
## to the back-to-back user agent server
[module::B2bua]
# Indicate whether the module is activated.
# Default: false
enabled=true
# A request/response enters module if the boolean filter evaluates
# to true. Ex: from.uri.domain contains 'sip.linphone.org', from.uri.domain
# in 'a.org b.org c.org', (to.uri.domain in 'a.org b.org c.org')
# && (user-agent == 'Linphone v2'). You can consult the full filter
# documentation here : https://wiki.linphone.org/xwiki/wiki/public/view/Flexisip/Configuration/Filter%20syntax/
# Default:
#filter=
# A sip uri where to send all the relevent requests.
#b2bua-server=sip:127.0.0.1:6067;transport=tcp
Transcrypterモード
メディア(RTP)暗号化の方式が異なるSIPクライアント同士の通信を中継・変換
たとえば、以下のような異なる暗号方式を使う SIP クライアント間で通話を成立させたいときに使います:
- 発信者(leg A):DTLS-SRTP
- 受信者(leg B):SDES-SRTP
このとき、Flexisipが間に立って、異なる暗号化方式を変換しながらRTPを中継
- Leg A:発信側
- Leg B:着信側
- Transcrypter:Leg A ↔ Leg B間でRTP暗号化方式の変換を行う中継機能
Leg Aの暗号化方式
Flexisip(B2BUA)は、発信者(Leg A)からの接続に対して、以下の暗号化方式を受入:
- 暗号なし(unencrypted RTP)
- SDES-SRTP
- DTLS-SRTP
- ZRTP
発信側がどの方式を使ってきても、B2BUAは受け入れて通話を確立。
Leg Bの暗号化方式の選択方法
通話のもう一方(Leg B)の暗号化方式は、次のようにしてFlexisipが選択:
1. 受信者のSIP URI(またはGRUU)に基づく
sip:[email protected] などの宛先アドレスや、GRUU(Globally Routable User URI)に基づいて、b2bua-server::trenscrypter セクションに定義されたルールにマッチさせて、受信者に使う暗号化方式を決定。
2. SDES(SDP Security Descriptions)方式の場合
さらに細かく、使用する SRTP crypto suite(例:AES_CM_128_HMAC_SHA1_80)に基づいて、適切な暗号設定を行うことが可能。
flexisip.confの設定については、下記のセクションを調整(IPv6のみで対応する場合)
注) 44000ユーザのみに適用するフィルタを設定。
ネットワークをIPv6限定にしたため、STUNサーバとMediaRelayは無効とした。
[global] ---> transports=sip:127.0.0.1:5060;transport=tcp sip:sip.example.com:5060;transport=tcp sips:sip.example.com:5061
[global] ---> rtp-bind-address=0.0.0.0 PUBLIC_IPV6_ADDRESS
[stun-server] ---> false
[conference-server] ---> nat-addresses=sip.example.com
[b2bua-server] ---> application=trenscrypter
[b2bua-server::trenscrypter] ---> outgoing-enc-regex=none .*@sip\.example\.com(;.*)?
[module::NatHelper] ---> ??? should be checked!
[module::B2bua] ---> filter=(to.uri.user contains '44000') || (from.uri.user contains '44000')
[module::Router] ---> ???
[module::MediaRelay] ---> enabled=false
負荷試験
通話品質を損なうことなく処理できる同時通話数。
表の見方
5 call/s renewing rate —> 365 calls – 64% CPU365通話を同時接続した状態で、1秒あたり5回のINVITE/BYEリクエストが来ても、サービス劣化なく通話品質を維持できる
Performance With Audio Transcoding
Codec scenario: G.711 ↔ G.729
| Flexisip version | 1 call/s renewing rate | 5 call/s renewing rate |
| 2.4.0-alpha-347 | 415 calls – 75% CPU | 365 calls – 64% CPU |
| 2.5.0-beta-34 | 460 calls – 78% CPU | 385 calls – 65% CPU |
Performance Without Transcoding
Codec scenario: G.729 ↔ G.729
| 2.4.0-alpha-347 | Unavailable | 445 calls – 40% CPU |
| 2.5.0-beta-34 | 790 calls – 59% CPU | 550 calls – 40% CPU |
