Kubernetes:kubectl
ConfigMapsの作成
$ kubectl create configmap ~
NginxやApacheの設定ファイルをConfigMapに登録し、各ポッドのマニフェストで指定
$ kubectl create configmap my-config --from-file=path/to/bar
$ kubectl create configmap my-config --from-env-file=path/to/bar.env
yaml出力して保存
$ kubectl create configmap nginx-config \
  --from-file=nginx.conf \
  --dry-run=client -o yaml > nginx-config.yaml
Secretsの作成
$ kubectl create secret generic ~
パスワードやAPIキーなどを含むファイルに関してはSecretとして登録し、各ポッドのマニフェストで指定
$ kubectl create secret generic my-secret --from-file=path/to/bar
$ kubectl create secret generic my-secret --from-env-file=path/to/bar.env
$ kubectl --help
kubectl controls the Kubernetes cluster manager.
 Find more information at: https://kubernetes.io/docs/reference/kubectl/
Basic Commands (Beginner):
  create          Create a resource from a file or from stdin
  expose          Take a replication controller, service, deployment or pod and expose it as a new Kubernetes service
  run             Run a particular image on the cluster
  set             Set specific features on objects
Basic Commands (Intermediate):
  explain         Get documentation for a resource
  get             Display one or many resources
  edit            Edit a resource on the server
  delete          Delete resources by file names, stdin, resources and names, or by resources and label selector
Deploy Commands:
  rollout         Manage the rollout of a resource
  scale           Set a new size for a deployment, replica set, or replication controller
  autoscale       Auto-scale a deployment, replica set, stateful set, or replication controller
Cluster Management Commands:
  certificate     Modify certificate resources
  cluster-info    Display cluster information
  top             Display resource (CPU/memory) usage
  cordon          Mark node as unschedulable
  uncordon        Mark node as schedulable
  drain           Drain node in preparation for maintenance
  taint           Update the taints on one or more nodes
Troubleshooting and Debugging Commands:
  describe        Show details of a specific resource or group of resources
  logs            Print the logs for a container in a pod
  attach          Attach to a running container
  exec            Execute a command in a container
  port-forward    Forward one or more local ports to a pod
  proxy           Run a proxy to the Kubernetes API server
  cp              Copy files and directories to and from containers
  auth            Inspect authorization
  debug           Create debugging sessions for troubleshooting workloads and nodes
  events          List events
Advanced Commands:
  diff            Diff the live version against a would-be applied version
  apply           Apply a configuration to a resource by file name or stdin
  patch           Update fields of a resource
  replace         Replace a resource by file name or stdin
  wait            Experimental: Wait for a specific condition on one or many resources
  kustomize       Build a kustomization target from a directory or URL
Settings Commands:
  label           Update the labels on a resource
  annotate        Update the annotations on a resource
  completion      Output shell completion code for the specified shell (bash, zsh, fish, or powershell)
Subcommands provided by plugins:
Other Commands:
  api-resources   Print the supported API resources on the server
  api-versions    Print the supported API versions on the server, in the form of "group/version"
  config          Modify kubeconfig files
  plugin          Provides utilities for interacting with plugins
  version         Print the client and server version information
Usage:
  kubectl [flags] [options]
Use "kubectl <command> --help" for more information about a given command.
Use "kubectl options" for a list of global command-line options (applies to all commands).
$ kubectl rollout ~
  # Rollback to the previous deployment
  $ kubectl rollout undo deployment/abc
  # Check the rollout status of a daemonset
  $ kubectl rollout status daemonset/foo
  # Restart a deployment
  $ kubectl rollout restart deployment/abc
  # Restart deployments with the 'app=nginx' label
  $ kubectl rollout restart deployment --selector=app=nginx
$ kubectl apply (-f FILENAME | -k DIRECTORY)
  # Apply the configuration in pod.json to a pod
  $ kubectl apply -f ./pod.json
  # Apply resources from a directory containing kustomization.yaml - e.g. dir/kustomization.yaml
  $ kubectl apply -k dir/
  # Apply the JSON passed into stdin to a pod
  $ cat pod.json | kubectl apply -f -
  # Apply the configuration from all files that end with '.json'
  $ kubectl apply -f '*.json'
  # Note: --prune is still in Alpha
  # Apply the configuration in manifest.yaml that matches label app=nginx and delete all other resources that are not in the file and match label app=nginx
  $ kubectl apply --prune -f manifest.yaml -l app=nginx
$ kubectl edit (RESOURCE/NAME | -f FILENAME)
  # Edit the service named 'registry'
  $ kubectl edit svc/registry
  # Use an alternative editor
  $ KUBE_EDITOR="nano" kubectl edit svc/registry
  # Edit the job 'myjob' in JSON using the v1 API format
  $ kubectl edit job.v1.batch/myjob -o json
  # Edit the deployment 'mydeployment' in YAML and save the modified config in its annotation
  $ kubectl edit deployment/mydeployment -o yaml --save-config
  # Edit the 'status' subresource for the 'mydeployment' deployment
  $ kubectl edit deployment mydeployment --subresource='status'
$ kubectl get ~
# List all pods in ps output format
  $ kubectl get pods
  # List all pods in ps output format with more information (such as node name)
  $ kubectl get pods -o wide
  # List a single replication controller with specified NAME in ps output format
  $ kubectl get replicationcontroller web
  # List deployments in JSON output format, in the "v1" version of the "apps" API group
  $ kubectl get deployments.v1.apps -o json
  # List a single pod in JSON output format
  $ kubectl get -o json pod web-pod-13je7
$ kubectl exec (POD | TYPE/NAME) [-c CONTAINER] [flags] – COMMAND [args…]
  # Get output from running the 'date' command from pod mypod, using the first container by default
  $ kubectl exec mypod -- date
  # Get output from running the 'date' command in ruby-container from pod mypod
  $ kubectl exec mypod -c ruby-container -- date
  # Switch to raw terminal mode; sends stdin to 'bash' in ruby-container from pod mypod
  # and sends stdout/stderr from 'bash' back to the client
  $ kubectl exec mypod -c ruby-container -i -t -- bash -il
  # List contents of /usr from the first container of pod mypod and sort by modification time
  # If the command you want to execute in the pod has any flags in common (e.g. -i),
  # you must use two dashes (--) to separate your command's flags/arguments
  # Also note, do not surround your command and its flags/arguments with quotes
  # unless that is how you would execute it normally (i.e., do ls -t /usr, not "ls -t /usr")
  $ kubectl exec mypod -i -t -- ls -t /usr
  # Get output from running 'date' command from the first pod of the deployment mydeployment, using the first container by default
  $ kubectl exec deploy/mydeployment -- date
  # Get output from running 'date' command from the first pod of the service myservice, using the first container by default
  $ kubectl exec svc/myservice -- date
$ kubectl api-resources
NAME                                SHORTNAMES   APIVERSION                        NAMESPACED   KIND
bindings                                         v1                                true         Binding
componentstatuses                   cs           v1                                false        ComponentStatus
configmaps                          cm           v1                                true         ConfigMap
endpoints                           ep           v1                                true         Endpoints
events                              ev           v1                                true         Event
limitranges                         limits       v1                                true         LimitRange
namespaces                          ns           v1                                false        Namespace
nodes                               no           v1                                false        Node
persistentvolumeclaims              pvc          v1                                true         PersistentVolumeClaim
persistentvolumes                   pv           v1                                false        PersistentVolume
pods                                po           v1                                true         Pod
podtemplates                                     v1                                true         PodTemplate
replicationcontrollers              rc           v1                                true         ReplicationController
resourcequotas                      quota        v1                                true         ResourceQuota
secrets                                          v1                                true         Secret
serviceaccounts                     sa           v1                                true         ServiceAccount
services                            svc          v1                                true         Service
challenges                                       acme.cert-manager.io/v1           true         Challenge
orders                                           acme.cert-manager.io/v1           true         Order
mutatingwebhookconfigurations                    admissionregistration.k8s.io/v1   false        MutatingWebhookConfiguration
validatingadmissionpolicies                      admissionregistration.k8s.io/v1   false        ValidatingAdmissionPolicy
validatingadmissionpolicybindings                admissionregistration.k8s.io/v1   false        ValidatingAdmissionPolicyBinding
validatingwebhookconfigurations                  admissionregistration.k8s.io/v1   false        ValidatingWebhookConfiguration
customresourcedefinitions           crd,crds     apiextensions.k8s.io/v1           false        CustomResourceDefinition
apiservices                                      apiregistration.k8s.io/v1         false        APIService
controllerrevisions                              apps/v1                           true         ControllerRevision
daemonsets                          ds           apps/v1                           true         DaemonSet
deployments                         deploy       apps/v1                           true         Deployment
replicasets                         rs           apps/v1                           true         ReplicaSet
statefulsets                        sts          apps/v1                           true         StatefulSet
selfsubjectreviews                               authentication.k8s.io/v1          false        SelfSubjectReview
tokenreviews                                     authentication.k8s.io/v1          false        TokenReview
localsubjectaccessreviews                        authorization.k8s.io/v1           true         LocalSubjectAccessReview
selfsubjectaccessreviews                         authorization.k8s.io/v1           false        SelfSubjectAccessReview
selfsubjectrulesreviews                          authorization.k8s.io/v1           false        SelfSubjectRulesReview
subjectaccessreviews                             authorization.k8s.io/v1           false        SubjectAccessReview
horizontalpodautoscalers            hpa          autoscaling/v2                    true         HorizontalPodAutoscaler
cronjobs                            cj           batch/v1                          true         CronJob
jobs                                             batch/v1                          true         Job
certificaterequests                 cr,crs       cert-manager.io/v1                true         CertificateRequest
certificates                        cert,certs   cert-manager.io/v1                true         Certificate
clusterissuers                                   cert-manager.io/v1                false        ClusterIssuer
issuers                                          cert-manager.io/v1                true         Issuer
certificatesigningrequests          csr          certificates.k8s.io/v1            false        CertificateSigningRequest
leases                                           coordination.k8s.io/v1            true         Lease
endpointslices                                   discovery.k8s.io/v1               true         EndpointSlice
events                              ev           events.k8s.io/v1                  true         Event
flowschemas                                      flowcontrol.apiserver.k8s.io/v1   false        FlowSchema
prioritylevelconfigurations                      flowcontrol.apiserver.k8s.io/v1   false        PriorityLevelConfiguration
ingressclasses                                   networking.k8s.io/v1              false        IngressClass
ingresses                           ing          networking.k8s.io/v1              true         Ingress
ipaddresses                         ip           networking.k8s.io/v1              false        IPAddress
networkpolicies                     netpol       networking.k8s.io/v1              true         NetworkPolicy
servicecidrs                                     networking.k8s.io/v1              false        ServiceCIDR
runtimeclasses                                   node.k8s.io/v1                    false        RuntimeClass
poddisruptionbudgets                pdb          policy/v1                         true         PodDisruptionBudget
clusterrolebindings                              rbac.authorization.k8s.io/v1      false        ClusterRoleBinding
clusterroles                                     rbac.authorization.k8s.io/v1      false        ClusterRole
rolebindings                                     rbac.authorization.k8s.io/v1      true         RoleBinding
roles                                            rbac.authorization.k8s.io/v1      true         Role
priorityclasses                     pc           scheduling.k8s.io/v1              false        PriorityClass
csidrivers                                       storage.k8s.io/v1                 false        CSIDriver
csinodes                                         storage.k8s.io/v1                 false        CSINode
csistoragecapacities                             storage.k8s.io/v1                 true         CSIStorageCapacity
storageclasses                      sc           storage.k8s.io/v1                 false        StorageClass
volumeattachments                                storage.k8s.io/v1                 false        VolumeAttachment
全Podの状態確認
kubectl get pods -A
kubectl get pods -o wide -A
Podの詳細確認
kubectl describe pod <pod名> -n <namespace>
全ノード確認
kubectl get nodes
kubectl describe node <ノード名>
マニフェスト適用
kubectl apply -f <yamlファイル>
リソース状態をYAML出力
kubectl get <リソース種類> <リソース名> -n <namespace> -o yaml
例:
kubectl get deployment web-server -n default -o yaml
Podのログ確認
kubectl logs <pod名> -n <namespace>
kubectl logs <pod名> -c <コンテナ名> -n <namespace>
コンテナ内に入る(シェル)
kubectl exec -it <pod名> -n <namespace> – /bin/sh
Podの強制削除(Terminating対応)
kubectl delete pod <pod名> -n <namespace> --grace-period=0 --force
PV / PVC 確認
kubectl get pvc -A
kubectl get pv
kubectl describe pvc <pvc名> -n <namespace>
